TwinTurbo.NET: Nissan 300ZX forum - Re: CAS, PTU, MAF, AAC, Coolant Temp Sensor, Injectors
Subject Re: CAS, PTU, MAF, AAC, Coolant Temp Sensor, Injectors
Posted by ZUL8TR on July 18, 2008 at 10:14 AM
  This message has been viewed 144 times.
In Reply To CAS, PTU, MAF, AAC, Coolant Temp Sensor, Injectors posted by Audioquest on July 18, 2008 at 09:09 AM
Message The injector connectors are a concern to remove since difficult to get to without significant removal of parts plus with the age the might just fall apart. Can the injectors be Ohm checked thru the main wiring harness at the computer under the dash with the battery disconnected?
I realize there is additional Ohms due to the harness wiring but any major differences between injectors should be seen.
Thanks
ZUL8TR in Orlando,FL
